Microtech eye candy
  • The MT knives shown here belonged to a Dutch forum member who wasn't really experienced in photographing his knives, describing & measuring them, as well as putting them up on a forum, so he asked me to do that for him a while ago.
    Because he had quite a special collection (most are sold now because auto's are illegal to own in the Netherlands now) i wanted to show them here as well.
    Microtech Socom Elite-A Tanto from 05/2001
    Specs:
    Length open: 23,0 cm
    Length closed: 13,0 cm
    Blade length: 10,0 cm
    Blade thickness: 4,45 mm
    Steel: 154CM with black coating
    Handle material: hard anodized 6061 aluminium with Kraton inlays
    Weight: 125 grams
    Microtech Socom Elite-A Tanto from 11/2005
    Specs:
    Length open: 23,3 cm
    Length closed: 13,3 cm
    Blade thickness: 4,43 mm
    Steel: D2
    Handle material: hard anodized 6061 aluminium with grip tape inlays
    Weight: 128 gram
    Erfahrungen mit kwakster ?
    Einmal editiert, zuletzt von kwakster ()
  • Microtech Lightfoot L.C.C D/A Carbon from 09/2001 (4th generation with anodized aluminum bolsters)
    The knife can be opened manually with the thumbstuds, but also automatically by swiveling the left bolster a bit to the right.
    Specs:
    Length open: 21,0 cm
    Length closed: 11,9 cm
    Blade length: 9,0 cm
    Blade thickness: 3,77 mm
    Steel: 154CM stainless
    Handle material: Carbonfiber scales & anodized aluminum bolsters on steel liners
    Weight: 167 grams
  • Microtech CMTX5-A from 10/2004
    This knife opens automatically by pushing on the end of the pocketclip, underneath which is the actuator which releases the blade.
    Specs:
    Length open: 20,6 cm
    Length closed: 11,6 cm
    Blade length: 8,9 cm
    Blade thickness: 3,23 mm
    Steel: S30V stainless with black coating
    Handle material: brown canvas Micarta on titanium liners
    Weight: 112 grams
  • Microtech Nemesis II Single Action OTF from 06/2003
    The knife opens automatically by pushing the button, after which the blade can be pulled back with a lever inside the back of the handle.
    Specs:
    Length opened: 21,6 cm
    Length closed: 12,2 cm
    Blade length: 9,2 cm
    Blade thickness: 3,75 mm
    Steel: most likely 154CM stainless (not marked)
    Handle material: hard anodized 6061 aluminum
    Weight: 94 grams
  • Microtech Combat Talon III Single Action OTF from 06/2003
    Specs:
    Length open: 21,5 cm
    Length closed: 12,5 cm
    Blade thickness: 4,44 mm
    Weight: 111 grams
  • Microtech Exodus Single Action OTF from 08/2001
    Specs:
    Length closed: 12,7 cm
    Steel: most likely 154CM, with a boron carbide coating
    Weight: 116 grams
  • Microtech Combat Talon II Single Action OTF from 02/2000 with blade ground by Walter Brend.
    Specs:
    Blade thickness: 4,48 mm
    Weight: 112 grams
  • Microtech Ultratech VI Double Action OTF Tanto from 08/2005
    The blade opens by pushing the actuator forward, and closes again by pulling it backwards.
    Specs:
    Length open: 20,5 cm
    Length closed: 11,8 cm
    Blade length: 8,5 cm
    Blade thickness: 3,2 mm
    Weight: 93 grams
  • Microtech Scarab Executive Double Action OTF tanto, and outside of the claw logo on the handle the knife is sterile (no markings)
    Specs:
    Length open: 20,4 cm
    Length closed: 11,7 cm
    Steel: most likely S30V stainless
    Handle material: hard anodized 6061 aluminum without inserts
    Weight: 115 grams
  • Microtech HALO III Single Action OTF from 07/2005
    Specs:
    Length open: 23,9 cm
    Length closed: 13,7 cm
    Blade length: 10,1 cm
    Blade thickness: 3,72 mm
    Steel: most likely S30V (not marked)
    Weight: 103 grams
  • Microtech prototype custom Daytona Double Action OTF van 08/2008, with dagger logo and serial number 11.
    Specs:
    Length opened: 19,0 cm (including "glassbreaker")
    Length closed: 11,0 cm
    Blade length: 8,0 cm
    Blade thickness: 3,29 mm
    Weight: 88 grams
  • Microtech custom Ultratech VI Double Action OTF
    Very rare.
    Specs:
    Length open: 21,3 cm (including "glassbreakers")
    Length closed: 12,6 cm
    Blade length: 8,6 cm
    Blade material: Carbon fiber/Titanium/Carbon fiber laminate
    Handle material: housing from hard anodized 6061 aluminum with carbon fiber top and actuator.
    Weight: 64 grams
  • Microtech custom Ultratech VI Double Action OTF with single edge stainless damascus blade.
    Specs:
    Length open: 20,3 cm
    Steel: stainless Damascus
    Handle material: hard anodized 6061 aluminum.
    Weight: 93 grams
    2 Mal editiert, zuletzt von kwakster ()
  • Microtech custom Ultratech VIII Double Action OTF with stainless steel handle & blued carbon steel Damascus dagger blade from 09/2008 and serial number 001
    Very rare.
    Specs:
    Length closed: 12,0 cm
    Blade thickness: 3,28 mm
    Steel: blued carbon steel Damascus
    Handle material: satin finished stainless steel
    Weight: 162 grams
  • Microtech custom Scarab Tanto Double Action OTF with partly polished blade & polished carbon fiber handle inserts.
    Sterile except the Scarab logo.
    Specs:
    Length open: 21,2 cm (including "glassbreakers")
    Blade thickness: 3,26 mm
    Handle material: hard anodized 6061 aluminum with polished carbon fiber inserts
    Weight: 117 grams
  • Microtech custom Scarab Double Action OTF with stainless Damascus dagger blade & blued hardware from 08/2006
    Specs:
    Length open: 21,8 cm (including "glassbreaker")
    Handle material: hard anodized 6061 aluminum with blued titanium screws & glassbreaker
    Weight: 118 grams
  • Microtech custom "Winter" Scarab Double Action OTF with polished dagger blade, silver colored handle with matching grip inlays, transparant actuator, and oversized titanium "glassbreaker".
    Specs:
    Length open: 22,5 cm (including "glassbreaker")
    Length closed: 13,9 cm
    Blade thickness: 3,25 mm
    Weight: 106 grams
  • Microtech prototype custom Daytona Double Action OTF with blued carbon Damascus blade from 08/2008 and serial number 002
    Specs:
    Length open: 19,0 cm (including "glassbreaker")
    Steel: blued carbon Damascus
    Handle material: hard anodized 6061 aluminum with polished carbon fiber inlays
    Weight: 84 grams
  • Microtech custom Scarab Double Action OTF with polished dagger blade & handle inlayed with black rayskin, blued titanium hardware & glassbreaker with ball bearing.
    Specs:
    Steelt: most likely S30V stainless (not marked)
    Handle material: hard anodized 6061 aluminum with black rayskin inlays
    Weight: 104 grams
